8 hours ago, dig-dug-dan said:
What was the issue with it?
Coil wasn't working so no spark, changed it, got spark but still wouldn't run.
Checked the compression,  cleaned the (brand new)  plug and the magnet on the flywheel. Cleaned the carb and it fired and ran fine
For the time it took to take the engine off its worth it to be able to clean and service the engine without kneeling down 😅😅
Good man. I find the more you take the engines out, the easier it becomes!
Done 1 or 20 now, mostly 200 tdis and td5s, so 8 bolts on this seems like a treat😅😅
7 hours ago, IronMike said:
I've officially written the past 3 weeks off as a total sh*t show!
Back on site today, first load of the day infact, and the pin for the outer on one site sheared.
Got it repaired fairly quickly, but sacked the rest of the day off!
Onwards to the APF tomorrow!
Seriously - give up on the Logbullet idea. You’ve given it an incredible chance but sometimes you need to admit it isn’t the right machine for the job you are doing. You need something bigger by the sounds of it, this thing will bankrupt you.
Are they called Logbullets because they go bang?
Alot?
1 hour ago, nepia said:
This could go the way of the cod fish thing given the right ammunition 😂
It could even go ballistic 🙂
