Anybody mentioned cryotherapy yet? Don't know much about it, its for sports injuries, a rubber cast filled with ice water which circulates via a tube into a thermos container continent more ice water. They make a cast/bladder/whatever you want to call it, for all major body areas and joints. You ware the thing and carry the thermos around with you, and it keeps the area cold for 6 hours.
Dave get an epicondylitis clasp asap from Boots or online.
Instantly helps a fair bit.
Going forward there's loads you do, you need to approach it from every angle. Physio, heat, cold, stretches, rest, cortisone jabs but most importantly changing the way you do things.
Good luck. It's a bastard.
I guess it falls in the back to the future but I had a problem with a VERY painful elbow various potions & doctors visits eased it a bit but it was still a problem One of my neighbors saw me having a painful movement he disappeared into his workshop & returned with a spray can & sprayed my elbow after an hour or so it was less painful & he said spray it 3 times a day after a week the pain had disappeared the Wonder Product WD40 it appears he had knee problems for years & in desperation & in pain he had spayed his knees & it had helped more than his doctors treatment Not saying it'sa cure all or even a cure at all just know it worked for 2 folk
Is this your neighbour ?
Edited by peatff
:confused1: WTF?????? :confused1::001_huh:
Copious amount of masturbation over guy porn works apparently. .......ask Joe newton.
Sent from my SM-N910F using Arbtalk mobile app
You misunderstood me Ian.
Since switching to man porn I barely touch myself, and that's what's cured it.
I understand that some people just need an excuse though. Knock yourself out. :thumbup:
If you're having painful movements, it's not your elbow you want to be spraying WD40 on. :001_smile:
