7 hours ago, AHPP said:
What a coincidence. I was just thinking about bolstering the springs on my van a few hours ago.
Yea but will they have Khriss is a twat on the brake drums😁
On 12/08/2021 at 19:02, Mike Hill said:
Just fitted a new rear spring and U bolts.I broke the spring last week.
I will do the other side when I can be arsed.
So, basically you have done half a job.. 🙄  K
(piss poor)
12 hours ago, AHPP said:
(What a coincidence. I was just thinking Khriss is a twat a few hours ago.)
Well if you put as much time in doing 'takedowns' as you put in trolling members on here, you could buy a new rigging kit. K
(piss poor)
It wouldnt have been as funny if I had written " Khriss is a twat" on both drums.
On 12/08/2021 at 16:08, difflock said:
Well, bollocks to that!
Ah broke me C52KS JD 'built like a brick shithouse" mower.
The drive wheel fell off.
A shitty biro thick bolt is all that carries the wheel.
It simply sheared.
Prob due to "rocking" in my attempts to dislodge stuck grass from beneath the deck.
Won't do that again!
Older
poorer
and
better informed(if no wiser)
Hmmmm!
Having failed to fine the replacement part of the intersnot, I called in with the local dealer, parts in hand.
After some time, head scratching and cross referencing.
Guess what?
JD has modified the design, to make it simpler and stronger I can only deduce.
So much for the origonal "brick shithouse" design then.
Though superlative service from the JD dealership, see linky
Edited by difflock
  • 3 months later...
