Also worth noting that when assisted pulling with a vehicle it is always better to pull off the front of it as the driver has a better view of what is happening and can either stop the cutter or tell wether to pull early or if it needs a quick snatch pull to try and recover a bad cut, however again this is all down to experience.
It's not about angles though it's about pull speed ... Watch the video again The truck stopped pulling it should not of until the tree was on the ground or there about a if your going to even attempt felling in those conditions and species.
If you are attempting to use pull-speed to 'steer' a falling tree then I suggest you are taking massive chances already, and possibly don't have a decent grasp on the principles of large tree felling. An assisted fell (winch, chipper, truck, tractor, pull rope etc) will get the tree moving in the required direction and can help counter a lean at the start of the fell. It should not be relied on to direct the tree once gravity takes over - that is down to the hinge (and occasionally a separate holding line to help prevent the hinge from failing). Pull speed had nothing to do with this balls up IMO - I would suggest the cutter has cocked the job up from the start. Pull direction was wrong, I would suggest the hinge has probably been severed (it certainly failed for one reason or another - the wind doesn't appear to have been accounted for at all) and there has been no attempt to maintain a 2 tree-length exclusion zone in any direction (never mind all the way around the tree!). Inexperience, bravado - probably a combination of the two could have had some very serious consequences here. IMO that was a reckless decision to go for the fell in those conditions in that location - I would think that the cutter's competencies will need to be looked at and at that point the company involved may have some questions to answer.
I think proving adequate training for all involved could cause problems.
It is critical to make full use of the hinge and toes, if you cut high or remove toes you are reducing the surface area where it is needed most. Removing toes, particularly on a leaning tree is increasing the problem.
Agree that was reckless in those conditions but If you pull over a heavily weighted back leaning tree it's better to pick the speed up as the centre of gravity starts pulling it off the hinge , it may be reckless but I've done it lots and it works on trees that other ways would of gone side ways , fine in the woods but not some thing you would attempt on a street or garden tree.
Whilst I (think) I acknowledge your point here, in practice it is too simplistic...I would suggest.
The AAAC / ArbAC process checks that skilled and competent personnel are in place at the time of the assessment visit (every 2 years.) Thereafter, and for the time in between, it is the nominated manger's responsibility and to ensure they are working in accord with industry good practice.
Isn't hindsight a wonderful thing. :001_huh:
Paul
Thanks for you reply Paul.
My concern is that the AA promotes good arboricultural practices. It can be expensive and hard work to gain your endorsement, but it's arguably worth it in the long run.
However when a video of this sort appears in the public domain, carried out by a company you've accredited, it completely nullifies everything that you as an association, and the companies who have proudly earned your accreditation are working towards.
so when a single doctor or nurse messes up and a patient dies because they did something stupid - it brings into question the relevant medical assessors and awarding bodies?
