Just now, Mark Bolam said:
Why aren’t panels compulsory on new builds?
Dunno . I saw on program , " click " I think it was where each roof tile and each flag stone on the path was actually a solar panel .
3 hours ago, Squaredy said:
Yes that is my situation; I am on a fixed price until the end of next year so I have just over a year to put up solar panels to charge my car.  And I can’t afford a fancy array with a feed in to the grid, I am going for about a 3kw off grid array on a garden room with no battery storage, so it should cost less than £4000, diy fitting of course.
Will you just go for charging off the 13A supply then? Should work out a lot cheaper than that, 6 panels for £1600 the inverter will be the interesting one because it will have to run off grid?? to avoid an application to the DNO.
The obvious cheap way would be to stay DC but I wouldn't know how to charge an EV that way.
2 minutes ago, Mark Bolam said:
There is no genuine reason for it not to be law.
It's down to freedom of choice.
I'm a bit perturbed by the amount of agricultural land that is being taken for solar pv arrays.
Given that also our farmers are not being given  a nod to get on and produce food in the face of similarly increased fertiliser prices I think government is failing in its prime purpose to steer industry.
We have already seen a large reduction in grain protein this year because farmers did not risk spending on fertiliser and in my view we should maximise agricultural output for human consumption because food on the global market will be needed for the poorer countries where people are going to starve. For us to exacerbate that problem by out bidding them is going to be tragic.
I'm sure it was something to do with insulation, allowing you to offset the need for panels if you desired.
However the new building regs have probably ended those shenanigans and making it mandatory, new regs were the other month I think.
There are also limits on the amount you can install if it's grid tie as the DNO is having trouble with the network. Transformer upgrades and cable sizes etc, the 16A per phase is in places far too high.
Edited by GarethM
The cost/profit thing is a non argument if it was compulsory though, it would be a level playing field.
Also it wouldn’t cost much in the grand scheme of things, not anywhere near the cost of retro fitting.
You’re spot on about the regs J, it’s a disgrace.
