Behind a tractor today, piled pretty height and catching on loads of branches, inches away from some by lines at one point. Not strapped down at all. I expect those things weight a bit and weren’t likely to go anywhere. Pretty sure he’d have been stopped though!
Tell that to my aunt whose car got written off by a bale landing on it about four weeks ago… fortunately it landed just behind the driver’s seat and there was no-one else in the car, six foot further forwards and it would have hit the windscreen.
Car was structurally not too bad but it has bowed the roof and as it was 11 years old, not going to be economic to repair.
  • Sad 1
21 minutes ago, daveatdave said:
the trailer illegal as well unless the law has been changed as its classed as 2 trailers ok to pull empty but not loaded
No one trailer, classed as lose coupled.
That be right Buh.
The front part is an trailer but it carries the weight of the trailer so not illegal.
7 A heavy motor car or a motor car not described in item 1, 3 or 4 2 trailers if one of them is a towing implement and part of the other is secured to and either rests on or is suspended from that implement, 1 trailer in any other case
8 An agricultural motor vehicle (a) in respect of trailers other than agricultural trailers and agricultural trailed appliances, such trailers as are permitted under items 5, 6 or 7 above,as the case may be; or (b) in respect of agricultural trailers and agricultural trailed appliances — (i) 2 unladen agricultural trailers, or (ii)1 agricultural trailer and 1 agricultural trailed appliance, or (iii)2 agricultural trailed appliances
...but it's regulation 83 of the construction and use act, I believe, that says a semi trailer and a dolly is a composite trailer and classed as one . 18tonne gross through
Which is what my post says... The weight of one is applied to the other.
  • 2 months later...
