500i bar length - 36" too big??
StihlGreen
If you go over 28” you will be limited really to skip chain.. that’s not something a lot of dealers have in stock so it’s not like you can wreck a chain and pick one up to finish the job from the shop down the road... there isn’t much a 28” bar won’t cut and the shorter the bar the easier it is to maintain and keep sharp and cut with to manoeuvre and fell a large tree, and given the state of a lot of bigger trees especially ash it would be safer to use bore cuts any way.. using a 48” bar on a stump yesterday I had forgot what a pita big bars are and also there is a bit of skill to using them effectively so swapped back to the 500i on a 28” just because it’s that much easier.. big bars for me only have one place really and that’s on a chainsaw mill.
  • Like 6
I have a 28inch with full comp and I will also be getting a 32 will skip chain
Interested to know your rationale for that, your uses etc? Just seems a bit similar. If I already had a 28, I’d want a 36. Like the op has a 20 so a 30 makes sense in my eyes.
As with most of this stuff ,  its because he can . 😊
On 31/12/2020 at 08:05, Rough Hewn said:
I’m pretty sure it’ll pull 36” full comp.
Personally 30” would be a good bar.
I run a 30” full comp on my 461 no problems.
Stateside they use 461’s with up to 42” full skip in softwoods.
Stateside they would run a 42" bar on a MS170 but it would have to be ported of course, the big thing now across the pond is a Barkbox exhaust mod and some of the crap i have read about this item and the improvements it makes to a saw, i cant believe the manufactures have not thought of it ?, 20% increase in power on my 20yr old 036 running a 30" bar and she rips,,,,,, thats the type of comment i have been reading,
Did you see the company offering:
Ms170
25” bar
Oversized felling dogs
Full wrap handle
Bark box
Videoed cutting 6” softwood
Absolutely amazing!
