8 minutes ago, topchippyles said:
Nope look at the tile lines and see if you can spot the difference ??
Yours is a continuous tile line at the eave. Whereas the other is staggered?
nice job BTW
Edited by Matthew Storrs
3 hours ago, TIMON said:
I’m not trying to minimise the impact of CV-19 but these statistics (from a couple of days ago) lend some perspective.
Just hope that the ‘cure’ isn’t more damaging than the virus itself.
Post the data from the next 2 months or so and it wont look so harmless. Coronavirus has barely got started on the worlds population
I have no idea why people keep playing it down. Death rates are estimated between and 1% and 3.4% and 70% of us need to have it before we get herd immunity. World populating is 7.7 billion and 70% get it thats 5.46 billion people. If just 1% die that is 546,000,000 people dead!
Edited by Woodworks
nice job BTW
Cheers mathew and that is the only one i have seen except the other 2 i have done.Where the secret is the distance between the ridge and the eaves coarse. Mine is well over a metre shorter between the top of the eyebrow  bottom eaves coarse and the  top ridge line.The distance from the fascia to the top ridge line on the main roof is 1.1 meters longer. How can one get the tiles to run in a straight line when you factor that in
Example if to have 10 rows of tiles and and they are spaced at 300 mm gauges which would give you a 3 metre rafter length give or take, Try and get those 10 rows of tines to work  at 2.5 metre rafter length in the middle of the roof then coming back to 3 metres the other end ??? in a straight line
Edited by topchippyles
Hello, I’m new here.
what are your thoughts on aerial rescue with the social distancing rules?
obviously I’d carry out an aerial rescue if needed but should we be climbing non emergency jobs at all....
Can we perform our job safely?
There’s theory and there is practice.....  The 2 rarely meet nicely in the middle because theory will almost always play second fiddle.
Firstly, staff working (esp climbing) should only be those without symptoms (of any sort not just C19.)
Yes, you ‘could’ be asymptomatic but what is the probability?
Second, how many genuine aerial rescues are conducted daily in UK Arb?
Answer, nobody knows but I’d take a punt it’s between 0 and zero.
Also, if we ‘know’ we have additional considerations we should moderate our working behaviour accordingly - add higher levels of risk mitigation.  Don’t do the more complex tasks.
If you combine the probability of those 2 adverse situations, factor in the likelihood of them BOTH being present at the same time, consider the potential impact of infection for a (presumed) young, fit and healthy worker then balance it all out against the financial, physiological and physical impact of NOT continuing in employment for the individual, the potential cumulative deleterious effect upon national GDP - and the consequential life expectancy effect of a >6% drop in GDP....
Then you’ll have your own personal answer!
Good luck, let us know what you come up with ?
Thanks for your reply.
i think you’ve hit the nail on the head there ?
cheers
Edited by Lemonsqueeza
Agreed.
We’re at about 1700 UK deaths attributed to C19 so far - granted, unfortunately, there is huge potential for that to go through a steep upward curve.
We already, routinely, have 50,000 excess winter cold deaths pa and I’d guess a lot of people have never even heard of EWD.
All I’m thinking is, is there parity in our approach to premature mortality?  Maybe this situation will make us think differently.
Probably no aerial rescues on a daily basis, I was part of a rescue team on the water for 11 years, never did go down the hole to rescue anyone.
cheers
It’s just a guess, but I’d take a punt on the risk of cross infection being vastly higher for those getting on the buses, trains, underground to go to work than it would be for a climber / rescuer.
I know ‘daily’ is a flawed basis for analysis. It should perhaps be pa or even longer and the consequence of needing it is also relevant.
Slightly aside, I consider the rescue climber requirement to be a fairly dull consideration anyway (minor injury = self recover, major injury wait 5-10 minutes for rescue whilst bleeding out or self recover - get to ground by route alpha) but that’s for another day.
