My EX50 Kioti only weights very little over 2000kg(but possibly/probably without the Kioti loader) and needs about a 500kg counterweight to be stable when maxxing out the loaders 1800kg lift capacity.
That is it will lift 2 full straps of dense masonary concrete blocks.
But would still be 3500kg towable when so configured.(& Certainly so with a sub 500kg counterweight)
And being cabless can enter low roofed buildings.
The only downside is the single speed PTO.
16 hours ago, woody paul said:
Get your self a piece of paper and write down what you can do with a telehandler and then a tractor with loader. You will not have the lift capacity with tractor but from what you say only got small lumps to move.
Cheap telehandler will be a heap of sh..
BUT we love old pieces of shit- on here ! K
perfect and just the right size.
It’s certainly been a good help just needs a weight block on the back as the grab has been made heavy but still lifts a good weight. Just need to take the loader off and put on the snow blade and gritter on next week so earns its keep all year round
If you are looking for a loader tractor, industrial tractors are well worth considering. They have much more hydraulic flow than an agricultural version, are no more complicated, have a nice easy to use joystick for the loader- and they are cheap! This one cost me £1700 and to get a normal tractor with this loading power would be far more than that!
the downside? No  3pl or spools on mine, but some do! Your budget would let you be a little bit more selective.
an old backhoe like an mf50 could be had on your budget, forks on the front, some kind of grab where a back bucket would be? Not something I have any experience with but the look like a lot of machine for the money?IMG_20181028_162427.thumb.jpg.75791588f2eaec6266181b5d97f4109b.jpg
I have Kubota STV40 compact tractor with front loader.
The bucket is great for moving logs, woodchip, and good sized bits of timber.
I bought a cheap 3 point mounted jib crane 3 years ago for one job. The crane did not cost much, we took the tractor on the plant trailer to a job 20 miles away and used it to drag large 90 straight felled conifers to the chipper.
I run the sawbench off the PTO, and use to run the splitter until I bought a new self powered one.
For another job we used the tractor with the front loader and also transport box on the back to shuttle timber from a wood to the customer's yard.
I have used it to help pull trees when straight felling.
I have also used a heavy duty flail mower on it for site clearance.
If I had a telehandler I could not do all of these jobs with it, and could not move it to the occasional job on a trailer behind Land Rover.
I also used to have a well restored Fordson Power Major tractor with a bigger loader on it, but the Kubota is way more useful than this was, and is so manoeverable.
How did you find it with the flail mower? I've got a 35 hp compact and have been toying with the idea of getting a flail mower but not sure if I've got enough grunt to drive it in the rougher stuff.. its a branson 3510. So probably more comparable to a 30hp kubota in reality, them korean horses don't seem as strong! What width was your flail?
