What was your opinion on Giant loader build quality.
What will the loader on the compact lift Mick?
I'm looking at similar options.
I reckon 300kg max. I try not to overload it as I'm told it's likely to ruin the pump.
I'm told, and I defer to the more knowledgeable, that a standard gearbox would be more robust for doing lots of lifting.
To butt in with my 0.5p worth.
We run an Avant 640 in work.
We also run a JD3720 hydrostatic tractor, with 300 series loader.
I really like and rate both.
Both are on turf tyres.
IF using the Avant with pallet forks one NEEDS hydraulic side-shift.
Not so with the wee tractor.
I would like to buy an Avant/Multione type machine, but scarce 2nd hand and bloody expensive.
And for my envisaged duties a wee tractor perhaps more versitile(with proper/Mechanical PTO)
Since the reach on the Avant is marginal.
PS
For fine control, i.e. power with precision, it HAS to be a hydrostatic transmission, EVERY time.
PPS
I understand Kubotas hydro transmission to be a bit "soft" and likely to lie down to heavy work/sustained road work.
Not so for the JD.
My dream tool is therefore a JD 4049M/4066M, with loader.
PS
PPS
Not so for the JD.
Would you say a compact tractor loader is as versatile as a avant/multione or is it really down to the size and turning circle with the tractor that people tend to do for the avant kind of machine?
Dont mess with a mini loader.... the point about these is their lift capacity compared to their size. I started with a Kubota compact which lifted next to nowt in comparison.
What multi one are you running it looks to be doing a smashing job ?
