Not very useful though
59 minutes ago, Stubby said:
Vesp is a bit of a tool . Don't know if its worth mentioning ...
3 hours ago, aspenarb said:
Kinell! took a few minutes to find this thread.
One for the bolt butchers and that includes myself. A small deburring gadget that goes in a cordless for tidying up the ends of bolts that have been mashed or cut down to length with a hacksaw. Makes easy work of it :thumbup1:
Link https://www.ebay.co.uk/itm/Laser-Tools-7510-External-Deburr-Chamfer-Tool-3MM-19MM-REPAIR-DAMAGED-BOLTS/362506781214?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
FD7958AC-C718-44C0-AA03-39E1AF318284_zps
16mm tow bar sized bolt
F912AA18-B8BE-4A07-9B60-4D04C88A5938_zps
Is an old method, cone centers are used on lathes fr chamfering components. K
I think any arb company on setting up should be made to purchase a compressor, 3 litres of white spirit and a box of cheap paint brushes!!!!
Judging by most of the saws I get in, they are all strangers to regular cleaning and servicing.
The other great thing about having a compressor to run an air line is that you can pump up your tyres without getting tired - see what I did;) and an impact gun makes your workshop sound like a Formula 1 garage....Oh, damn I am good....work it out!
Edited by spudulike
The other great thing about having a compressor to run an air line is that you can pump up your tires without getting tyred - see what I did[emoji6] and an impact gun makes your workshop sound like a Formula 1 garage....Oh, damn I am good....work it out!
Impact gun formula 1 sounds are basically why I bought a compressor, all other uses are of secondary Interest
  • Haha 3
I have had a small compressor for about 20 years . I have had 2 slow punctures in the back tiers of my truck for almost as long ?
  • Haha 4
I’ve a slow on one of my rangers rears and the fronts need balancing..... i’ll get new tyres first lol
slows been here for a good few years also ?
These cord pin end terminals are worth a mention, brilliant on things like tow sockets where the screw will eat through the cable if you overtighten and any hairy bits you miss touch each other knocking fuses out.
https://www.ebay.co.uk/itm/800Pcs-AWG-10-22-Wire-Copper-Crimp-Connector-Insulated-Cord-Pin-End-Terminal-/273147641709?hash=item3f98de3f6d
Just bare back the cable, double it up, slide it to the end of the ferrule ,push it into the terminal block and screw it down, no special tools needed
Bob
873E0A58-AC96-4FA9-8B57-870C034EE25C_zps
28EBAC2B-4732-4085-8CBC-44761848E4C1_zps
  • Like 6
