3 hours ago, Squaredy said:
Yes that is my situation; I am on a fixed price until the end of next year so I have just over a year to put up solar panels to charge my car.  And I can’t afford a fancy array with a feed in to the grid, I am going for about a 3kw off grid array on a garden room with no battery storage, so it should cost less than £4000, diy fitting of course.
Will you just go for charging off the 13A supply then? Should work out a lot cheaper than that, 6 panels for £1600 the inverter will be the interesting one because it will have to run off grid?? to avoid an application to the DNO.
The obvious cheap way would be to stay DC but I wouldn't know how to charge an EV that way.
2 minutes ago, Mark Bolam said:
There is no genuine reason for it not to be law.
It's down to freedom of choice.
I'm a bit perturbed by the amount of agricultural land that is being taken for solar pv arrays.
Given that also our farmers are not being given  a nod to get on and produce food in the face of similarly increased fertiliser prices I think government is failing in its prime purpose to steer industry.
We have already seen a large reduction in grain protein this year because farmers did not risk spending on fertiliser and in my view we should maximise agricultural output for human consumption because food on the global market will be needed for the poorer countries where people are going to starve. For us to exacerbate that problem by out bidding them is going to be tragic.
I'm sure it was something to do with insulation, allowing you to offset the need for panels if you desired.
However the new building regs have probably ended those shenanigans and making it mandatory, new regs were the other month I think.
There are also limits on the amount you can install if it's grid tie as the DNO is having trouble with the network. Transformer upgrades and cable sizes etc, the 16A per phase is in places far too high.
Edited by GarethM
55 minutes ago, Mark Bolam said:
Why aren’t panels compulsory on new builds?
33 minutes ago, Woodworks said:
It's bonkers. To fair not every house will have a suitable elevation but most will
It all comes down to cost and profit for the building companies.
90% plus of all houses built in the UK are built are constructed to the absolute lowest possible standard. Building companies have historically heavily lobbied successive governments to keep building regs to the lowest possible standard. Not only is it ridiculous that all new houses don't have solar panels, but the fact that we're still building homes with only double glazing defies logic. The average garage here in Sweden is better insulated.
What we're seeing in the UK now is the consequence of decades of inadequate regulation of the house building industry. We've had the technology for years to build houses that require virtually no heating and yet we still accept the little shitty rabbit hutches that Persimmon and the like throw up and expect us to get excited about.
If summers of 40c plus become common place, a great many people are going to suffer horrendously, especially if electricity is so expensive that AC is uneconomical.
  • Like 6
The cost/profit thing is a non argument if it was compulsory though, it would be a level playing field.
Also it wouldn’t cost much in the grand scheme of things, not anywhere near the cost of retro fitting.
You’re spot on about the regs J, it’s a disgrace.
The building companies use their undue and unfair influence on politicians to ensure that they aren't mandated to build anything more than the minimum. They'll claim that there isn't market demand for green technologies, but it's bollocks. They don't offer them, so what choice does the consumer have?
The house industry in the UK is something akin to having the technology to build Teslas but offering nothing more than Morris Minors. It's utterly ridiculous.
I'll state again - our 1957 house in Sweden (with original, albeit fair sophisticated for the time, windows) uses 10 times less heat per square metre than our 1860s/1930s farm cottage in Devon. And that's despite a Devon winter averaging 9-11c warmer than here.
There's a house four doors away that with it's rooftop solar array and extra insulation costs £800 a year to run, combined heat and power. For 210 square metres.
