I just bent my fork whilst trying to lift the dog!
Should have lifted at the centre of gravity. Obviously putting the tine in his lug hole created an off-centre load and the torsional forces initiated overloading doh!:biggrin:
Particularly tough bit of wood or just stress over time? Guessing the latter....if so how much wood has it done?
6 years of stress and i probably use that one the most.
The seal on the saw motor started leaking aswell, so that's off getting reasealed. Not bad really considering its in daily use.
bent not broke, surprised my self by recovering situation with little press, needed support blocks! to stop things bending that should not be, now as straight as a straight...ish thing ( a bit weaker possibly)
No names mentioned here but can you imagine the call to the boss about his new GreenMech which had a lump drop on it?
  • Sad 2
