Willow, thuja etc all burns and is arguably better than euc to someone who doesn't have a splitter. Far more efficient to swing an axe five times and achieve four splits than swing an axe five times and have it bounce off four times.
Edited by AHPP
1 hour ago, woody paul said:
Lot of people don't like it as takes long time to dry out.
Don't tell these old log goblins that, at 80 they may not get a chance
 to burn it 😀
Bob
  • Haha 4
Years ago I took a big Eucalyptus down disced trunk in 9inch thick piece and then had to quarter them to lift them into wheel barrow.
After about a year sitting in a pile, borrow a 90hp tractor and Hycrak splitter, stooled tractor no end of times. And had easy bits with a cut with saw.
Does anyone know of any traditional uses of Eucalyptus timber, that reflected it's great strength? Thinking about Elm being used for cartwheel naves, hubs, etc.
I'm guessing not as there was no technological civilisation in Australia until Britain took over.
Telegraph poles
On 02/08/2025 at 15:31, aspenarb said:
Euc is a bit slow, this would normally be gone within the hour.
Bob
Bit far for me but it would have gone if it was round here.
Done a couple of smaller ones recently, split the wood up in the same afternoon while it's still soft and then seems to dry ok. Otherwise if I can't split it straight away I just dump it to biomass place, no point messing around once it's gone hard.
1 hour ago, Steven P said:
I'd take some just for the challenge now!
There are ones that split and ones that don't, if the grains double twisted it does literally just bounce back the axe or maul.
I burn a reasonable amount of euc that I grow and coppice myself. I leave it lying sometimes for 3 months or more after felling and don't find it hard to split with an axe. Though I don't tend to let it get much bigger than 25cm dia or so before I coppice it. I also find it seasons quickly in a polytunnel, once split. The bark is thick & quite watertight, though.
