On 18/10/2025 at 21:35, AHPP said:
If you need to nibble so you can throw pieces somewhere safe rather than just shove them off, you're better off nibbling cubier blocks than big diameter, thin cookies. Short bar rather than long. Digs in, plunges etc better. I even carry a few of these with lag bolts/screws for if you need to tether a chunk that's in danger of falling off while you cut it, like a big beech knuckle.
Why cubier blocks? Chainsaw or physics considerations?
Easier not having to wrestle a long bar about out of the cut. And in the cut, easier to plunge/carve in any direction. Plus a cubier load you can get closer to your body. Big biscuits, the weight can be far away from you, more friction on a bigger face, they can seesaw on the edge of the stick etc. Just more awkward.
And it's easier to sharpen short bars so they cut straight enough at their full length. You'll find a lot of big bars in the wild that can't.
Edited by AHPP
Well went and felled 15 spruce and cedar trees other day, 2 of use on site and little digger with fixed grab, all went very well after a late start at 10.30am but got all 15 down processed and stacked ready fir collection and all brash pushed in to a big burn pit, site was nice n dry and hardly made a mark on the ground, then today I went to pick first load of log up and what a difference the ground was after the rain we have had,, last photo was this aft parked up and all dry abd as soon as I got on my seat behind crane the heaven opened hence puss wet through in no time and wagon stood in 6" of water 😦😦
  • Like 9
