Security / powerful torch
youngsbury
So my old trusty truck / security torch is finally giving up the ghost and looking for a replacement. Don’t want to many functions just high beam and a low ! Will be used around the place for general use and keeping an eye on things. looking around the £80-90 max range.
WWW.MANOMANO.CO.UK
IN STOCK: best prices on Nightsearcher TRIO-550 Rechargeable Search Light Handlamp Yellow, ZT1026281X.
Lasts for hours, nearly as good as a car headlight, the dim beam  is switched by holding the switch down longer  and it functions as a mains failure light, flashing if the USB charge power is lost. Mine is 7 years old now and seems fines still.
Got one of these and its hellish bright. Use as a head-torch or handheld. Not the best balanced head-torch I have but when you want bright it takes some beating
● Enhanced performance!Cheaper than the 1st generation●Brighter!Max 2500 lumens: Olight's No.1...
1 hour ago, openspaceman said:
WWW.MANOMANO.CO.UK
I've got one of the older Nightsearcher Trio LED and they're a good hardy torch, large size so easy to find, great for long distance, but hopeless for anything close up ie under 10m.
Nightsearcher are a decent brand, used by police/railways etc
