1 minute ago, trigger_andy said:
That only works if you don’t advertise.
If you have enough customers ( as he does ) then you don't need to advertise .
But for those that do they run the risk of being dobbed in. Even if you don’t and someone was of the mind to dob you in you’ll be known locally and still be at risk. Not that easy to fly completely below the radar.
Ok . So someone dobs you in . Who do they dob you in to , and what happens next .
Just now, Peasgood said:
Special Branch.
I thought Andy would have come back with that sooner  😁. In all seriousness I can't se it working . Ok those who register will be fine those who don't , who already have a good product and  regular customers will still be ok .
I thought Andy would have come back with that sooner  [emoji16]. In all seriousness I can't se it working . Ok those who register will be fine those who don't , who already have a good product and  regular customers will still be ok .
I hope you’re right. But never underestimate the ability of people to be vindictive sneaky little bitches. 🤣If they’re paying into it and you’re not and there’s a path to eliminate you and take your customers then I can see some doing just that.
I hear you, but it would take more than that to eliminate you.
From Woodsure website:
Enforcement
A common question we have been getting relates to enforcement. This is covered under Part 6 of the new Regulations and identifies local authorities as the body responsible for enforcement of the Regulations. For the purposes of the regulation, “local authority” means—
  • the Common Council for the City of London;
  • London Borough Council;
  • the Council of the Isles of Scilly;
  • a county council;
  • a district council for an area in which there is no county council.
There are a number of measures available for the local authority to assist in enforcing the regulations, such as:
  1. enter a supplier’s premises at any reasonable time;
  2. inspect a supplier’s goods;
  3. make test purchases of a supplier’s goods;
  4. require a supplier to produce documents or to provide information;
  5. question a supplier or officers or employees of a supplier.
Additionally, compliance checks can be undertaken. An enforcement officer may check:
Fines
You could be fined if:
  • you sell unauthorised fuel
  • you’ve stored fuel so it has a moisture content of more than 20%
  • the fuel does not have the ‘Ready to Burn’ logo or is not labelled correctly
You could get a:
  • £300 fixed penalty fine issued by your local authority
  • fine of more than £300 depending on the severity of the offence issued by the courts
Councils are understaffed enough as it is. I can't see much enforcement if any happening anytime soon. I'll chance the £300 fine!
The problem isn't the retailers of firewood, it is the bloody morons who don't have a clue about the moisture holding properties of wood and try to burn it wet (even when the wood may have been sold to them dry), don't understand the 'physics of fire' such that they produce a load of smouldering embers and in many cases don't know how their appliances actually work so can't adjust airflow, for example, to alter the characteristics of the fire.
I source my own firewood, from diseased trees that have been condemned and felled. I season it for over 2 years under cover outdoors with plenty of airflow, cutting and splitting it to let it dry out. If my stocks get high, I may sell a bag on to a family member. There isn't a woodsure logo to be seen, but the logs sure burn brilliantly because we know what we are doing.
The legislation is being forced in because of idiots who don't have a clue.
Well you wouldn't expect a successfully lobbied government to actually target the right people would you?  They wouldn't vote the right way again if the government did!
