How does one keep logs at 20% at this time of year ?????
I completely agree with all your sentiments on flooding. It's all a problem of our own making, again. Trying to further control/constrain nature by dredging, straightening and embanking rivers is not the answer,. Instead we need to step back and let the natural environment regulate itself.
Also, we need more beavers! Seriously.
It will be interesting if farmers take and use the new carbon schemes to plant up these areas that require a lot of effort to drain and would be better suited to trees.. I hope so,the Feild in the picture is a prime example of one that should of never been put in to arable production.
On the reverse side of this some farmers including ourselves are moving to mob grazing and other similar techniques which have multiple benefits. Only recently taken on management of my parents small farm and we are already seeing dramatically reduced runoff in wet periods due to the longer sword length.
WWW.SOILASSOCIATION.ORG
19 minutes ago, Woodworks said:
And remind us how much do they charge for this service?
Woodsure
122.40 Registration Fee
385.20 Annual audit
232.80 Point of sale checks (up to 2000m3 annual fee)
Non-compliance fee should a supplier be reported or found to be not complying, likely to be circa. 130 - 230.
Fixed penalty for non-compliance 300.
11 hours ago, headgroundsman said:
Either use a kiln wacking out heat to dry it and then vacuum seal it in industrial plastic or import it from the other side of the world. This is the obvious answer!
This will definitely offset the additional carbon caused by the 2% extra moisture... Add a nice bit of single use plastic wrap to the mix too and we're onto a winner. This government 🙄
I'd be genuinely interested to know how much carbon is used to kiln dry timber plus the carbon released by the timber whilst drying and then compare that to the amount of additional carbon when burning wood when it's at 22%. The additional transport, storage, kiln drying etc etc can't be less carbon surely
Edited by Paddy1000111
That's interesting I've not heard of mob grazing until now, sounds good all round. It's within the same concept of nature regulating itself. Reminds me of how grazing works on the African Savannah.
I was listening to this earlier. Very much in the theme of what's wrong with our current agricultural systems.
WWW.BBC.CO.UK
The pressure to squeeze more out of the land intensifies as the farm risks ruin.
12 hours ago, difflock said:
Must check some o mine tomorrow!
How will you check them?
One of the things @Woodworks and I have previously discussed is how moisture meters are calibrated and the same holds true for the tables of equilibrium moisture content he cited.  Most lumber drying measures moisture on a dry weight basis. I think the recent legalisation for firewood is measured on a wet weight basis??
Now if the example of 21% moisture content being in equilibrium with air at 90%RH is based on moisture as a percentage of dry weight  then that equates to 17.4% wet weight basis. Also look down the chart for cities in america, are they all seriously dryer than UK as not one of them shows an EMC of higher than 18%. I'd like to see a real experiment of a log of moisture content determined by oven drying suspended in free air under cover outside.
@Mike Hill mentions airflow and this is far more significant than one might think because diffusion alone isn’t enough to move moist air away from the log. My little experiments with single logs point to this also as they seem to do better than logs in my log shed. I should have weighed some sample logs and marked them before embedding them as I filled the store in May.
Just consider how wet roads dry out in a day without rain even in January, so drying is still taking place mid winter albeit not much but if the wind is free...
A m3 stack of beech logs at 21% mc wwb probably weighs about 280kg and has about 53kg of water, to get it to 19% means removing 6.25kg of water and the latent heat of evaporation that needs is 4kWh ( the heat in a1kg of 20%mc log), the trouble is that if the moisture in the logs is homogeneous the temperature would need to be high enough to get to all the log and the heat losses from that could exceed the heat needed to vaporise the water.  One way would be a first in first out  queue blowing warm air from the first out end with maybe4 days log deliveries in the queue  in an insulated tunnel to polish off the few kg of moisture.
We can have a separate discussion on how come there is a need for legislation and about selling wet wood when everyone knows dry wood burns well and green wood doesn't. It's a bit like gun law once garage forecourts stop selling wet wood then the people burning it are likely not buying it but getting it free and burning on an open fire.
I oven dry to get the definitive MC of air dried logs.
It is possible to ' keep logs at 20% at this time of year' depending on your region and topography of the site where you store.
Basically a far larger earlier investment in timber, a much longer lead time, timber dried to below 20% considerably earlier than you have ever done before, good air circulation throughout Autumn / winter and meticulous process management from start to finish.
By no stretch of the imagination is this an easy task and never a 100% guarantee of success.
IMO you will always be sailing close to the wind, however hard you work at things, just need to remain positive.
Holistic grazing is the same ? One of my neighbours introduced me to it a few years back , it’s some thing I mean to do but only have 2-4 beasts max usually so just alternate them between two Feild’s in summer and they have the roam the whole lot now, if I stand and look down in to the valley you can see that’s exactly how are forefathers farmed by the traces of old boundary walls and paddocks unlike the big open heavily stocked expanses we have now.
I think mob grazing is part of what's termed regenerative agriculture, at least in the States where it seems to be taking off slowly: YouTube has many vids on the subject.  It does make sense, especially the part where you don't destroy the soil structure every year with heavy fossil fuel-burning machines.
Matty and Beau; it looks like you're ahead of the game by returning to ancient practice - talk about reinventing the wheel 😂
Sorry about that - you get a big thumb up from me for doing it
Edited by nepia
Confess to forgetting that. Had better do some more oven drying tests on the wood reading 23%
