Bought one of these jugs about 3 months ago great no more crap, dust or dead spiders.:thumbup:
[ATTACH]217079[/ATTACH]
Yup! Started using one of them early last year. Buy oil in 25ltrs now. No spilling and easy to fill those machines in hard to get places!
  • 4 weeks later...
Retractable air line in Aldi at the moment , its the soft stuff that stays pliable when cold. Got one for the chainsaw shed for blowing out the saws, £20
Bob
I will second that, bring them on :)
I will take some snaps of my chainsaw holding device, its a gem for working on saws.
Bob
Its been in hibernation so I dug it out today ( feck loads of saw maintainence to do :thumbdown: ) , cleaned it up,made it look prety and bolted it back on the bench . Very easy to make from a lump of 1"1/4 waterpipe, short piece of 35mm solid rod , some 50x10mm flate plate, and a 16 mm bolt.
The adapters bolt on where the bar would go so you will need to make a few different ones to suit, I stamp them up so I know what they fit. You also need to trim them down as much as possible to to give you access to the clutch/brake etc. Its much easier than chasing a saw around a bench, most jobs can be done without removing it from the fixture. Makes this work so much easier
Bob
Edited by aspenarb
