1 hour ago, Woodworks said:
It's bonkers. To fair not every house will have a suitable elevation but most will
I seem to remember reading that in Milton Keynes new builds do have to have solar panels, and that was many years ago.  Do I remember right I wonder?
1 hour ago, openspaceman said:
Will you just go for charging off the 13A supply then? Should work out a lot cheaper than that, 6 panels for £1600 the inverter will be the interesting one because it will have to run off grid?? to avoid an application to the DNO.
The obvious cheap way would be to stay DC but I wouldn't know how to charge an EV that way.
I am getting it specced out by a local firm, not sure of the details yet.  I think it will be AC though, and then of course converted back to DC by the car!
1 hour ago, Mark Bolam said:
The choice not to have free, renewable energy?
It is not free and when you consider the return on capital it is not actually a good investment compared with quite a few other investments but...
56 minutes ago, Big J said:
We've had the technology for years to build houses that require virtually no heating
Well I agree with you to a large extent but the problem is the old houses,like mine, that defy straightforward solutions to insulate them. They are a very large portion of the housing stock, no reason that new builds couldn't be better though.
Does anyone have figures for number of houses, semi-detached, terraced  verses flats, apartments etc,
Also  it is something to do with the extremely poor standard of policing building regulations  that means a lot of techniques for preventing things like cold bridging are compromised by poor application. I do actually have a bit of experience in trying to get building workers to adhere to the instructions.
BTW the latest bit of building regulations seem to make use of plastic insulation nearly obligatory over rockwool (which I prefer).
That equation is changing pretty rapidly though. When we got our PV on the FITs many moaned about the "ridiculous amount of money we get paid" through the FIT (45p per kWh) Payback was around 7 years
Now panels are half the price and electric is soon to hit 50p per kWh from what I hear
5 minutes ago, Mark Bolam said:
Maybe free was the wrong word, but a pittance on to the cost of a £500k investment.
With the benefit of then not having a £3k leccy bill every year.
Well of course I agree, I bought my panels at the same time my car was new, they were similar in price, and I chose to forgo a modest new car at the time and acquired it five years later instead.
BTW in the absence of panels and battery my electricity bill would still only be £1050 at today's capped price so one needs to be careful with what is used anyway.
Yes that is probably the easy way, voltage from panels converted to AC by an off grid inverter and then charge car with a Zappi.
I suspect that will be a 15-20% poorer performance than if you could run DC straight from the panels and into the car battery via a MPPT charger.
but no one new electricity would get that expensive , it , and gas were cheap , and no one knows what it will be in a year or two either ... forward planning is very difficult , also new builds have much better insulation than old properties ...
Expanding on the point about PV panels on new builds, a very good one..What a collosal missed opportunity. As well as that, what about mandating the installation of them on the roofs of new industrial/commercial buildings, distribution centres in particular.  There's loads of the buggers around these days, with more springing up every day.  A lot of them are immense, you're talking acres square of roof space, rather than feet. There must be a huge potential for solar energy capture there. Plus an economy of scale factor at play. It's got to be more efficient to do one big flat industrial roof install rather than hundreds of small pitched domestic ones.
In a similar vein; we ought to be mandating rainwater harvesting on all new builds as well, both domestic and industrial/commercial. Not a bad approach to the ever worsening issues of flooding and drought.
