Up to yer nuts in it thread
aspenarb
13 minutes ago, difflock said:
From the surrounding swamp, this result should hardly have been a surprise to the driver  .  .  .
However I too have been known to push my luck9_9
It’s a self-set woodland in a quarry that is going to be at the bottom of a lake once the pumps are turned off - pretty wet site (that’s largely navigable as you are running across the tops of rootplates mostly). However, it is possible to break through/get hung up, which is why the winch has been on from the start. Getting stuck is getting a bit dull now though!
  • 10 months later...
