On 26/06/2024 at 21:39, PeteB said:
Holley 4 Barrel leaked so bad both externally and internally, the high pressure pump filled the sump up!
Holy crap, how big is the flaming chipper?! 😮
Andy Gould and myself did talk of putting a big block in a 1928, open headers, bug scoop all the good stuff!
  • 1 month later...
Three years and three days after it first fell off, I finally finely fettled the runner with fusion and fitted fresh rollers. I’ll be anxious shutting the door for a while yet. I keep flinching like a wife with one black eye already, expecting it to fall off again.
Edited by AHPP
  • 3 months later...
Too many to list but this is annoying. Thought it smelt of diesel strongly.... had a look and diesel leaking from where the wires go into the pump!
Must be cheap crap .... did consider removing it, cleaning it up and epoxy resin around the wires but would presume this would seep through again at some point.
Lost a link and track came off. Only seems to happen when they're balls deep. Then snapped my winch cable pulling it out the muck, then the engine cut out,filters blocked. Should have stayed in bed
  • Sad 8
  • 4 weeks later...
All my things that run on red seem to be getting blocked filters in this recent cold spell. Genny,tractors,chipper,digger.
See through filter is waxy af,when brought inside it liqifies fine.
Does anybody add anything to their red?
Petrol mix?antigelling agent?
Driving me nuts
  • 1 month later...
Driving me nuts
Most waxing is down to the water content Bill, made worse with low fuel levels because of water content as a percentage. Not hard to check holding tanks and machines, there is a paste called Kolorkut , smear a bit on a stick and dip the tanks, it shows up water within as a red marker.
Bob
Water red diesel mix.
Edited by aspenarb
