57 minutes ago, maybelateron said:
 "mechanical contempt"
Having that.
Edited by AHPP
Knowing how a machine runs and works is key in this business, if it brakes down you need it fix for the next day or on that day to finish job. Only the other day switch packed up on eclectic supply to 6 way valve to work grab and rotator on little loader. So I pulled wires from work light on boom and wire 6 way valve to it and used light switch instead.
I Like that! Sometimes you've to be crafty to get through the day :D
Few times lads working for me shrug shoulders.... machine not working yet not checked owt over.
Loose battery terminal on the teleporter other week. Easy stuff and I was away in seconds. The lads would be there thumb up arses waiting for someone to come fix it
That’s often better than ‘we tried to fix it’. Nothing more dangerous than someone who thinks they know but are still as thick as shit.
Larger firms that run machinery have dedicated mechanics for a reason.
It’s hard for folk like you and me who just look at it and have it fixed in a jiffy to realise that common sense and mechanical understanding really isn’t common any more.
Edited by doobin
11 hours ago, Mike Hill said:
Lower feed roller bearing came off.
Welded it back on.
I know it's a pretty gapping repair since the studs fell out.
However I have planned alot of work on the chipper,alas the Norwegian Jensen dealer doesn't give a toss  about replying to emails it seems.
  • 1 month later...
What a week all fairly mild in fairness.
Got to site machine wouldn't start to get it off the trailer... found a broken green corroded wire. Quick bodge for the day and back at it.
Nearly bogged machine down, got out of situation to find track had come off idler, no grease gun or jack etc on site! Managed to rough arse it back on with a ratchet strap and a pick axe we found on site.
Yesterday the chipper cut out on us... ALT on the screen.... quick look shredded alternator belt. Middle of a field 😂 Jase at greenmech tech sorted me some numbers out to get one sorted. Always snaps or rubs where the numbers are!  Managed to go get one from gsf in local town thankfully and back at it!
Makes me wonder how the hell folk get on who have to wait for someone to come out when machines break down etc must waste full days at times
I think if you run kit you have to end up being handy on the spanners. Id never be able to afford to get someone out to do everything.
Last year I bought a swage machine and loads of hydraulic pipes and fittings so now we do all our own pipes, the time saving is massive.
Some understanding of how it works certainly helps.
I have worked with professional tree workers for whom a chipper is just a magic box where wood goes in, chip comes out.
What happens in between is of zero interest.
  • Haha 3
