HI MATE they can not do that mate if your only burning hedge cutting thanks jon :thumbup:
Not true, as youcan burn waste removed from elsewhere, only if the hedgecuttings have come from the land you are burning on. EA will come down on him hard.
why not burn when the wind is in a different direction, or at night when the council is closed!!
  • Replies 48
It's quite straight forward:
D7 exemption required if burning at the site the waste was generated (or get the customer to light the fire as a domestic bonfire.)
If it's untreated green waste such as arisings from hedge trimming, the waste code is 02 01 03 Plant Tissue AN (absolute non-hazard)
If it is being moved from the site where it was generated, registration on the lower tier as a waste carrier is required and a waste transfer ticket required using the code above.
That's all you need if it's going to a registered waste reception centre.
If you are batching / storing / burning at your own site you're into a whole raft of registrations and licences as a waste reception / processing centre.
If the council are on the case it's probably wise to abide by the regs.
High price for disposal of Green Waste! - Sheffield Forum
http://arbtalk.co.uk/forum/general-chat/84135-20-000-fine-burning-waste.html
Bonfire Nuisance in Your Neighbourhood
let all the brash dry before burning - less smoke, and don't use a tyre to start your fire, that alone is trouble. use some dry bash as kindling, then burn at night.
HI DAN what saying just go on doing then see what will happen thanks all the best with it jon :thumbup:
Why not make or invest in an air burner, or just up your price to the customer and let them pay for the disposal. It should all be included in the quote.
Alternatively you could always just tip it in a lay-by or country lane like many individuals do near me.
If its agricultural land your burning on then you need to register an exemption with defra or ea I forget which now and that allows you to bring in and burn so many m3 a year from yoyr own jobs on your own land.
But he's not burning stuff from his own land.
