Just to add a completely new dimension into the mix, I came across this for the first time today.
The background story is.
I was asked to plant several types of Ash from various parts of the world as a controlled experiment to monitor species resilience to ADB on an FC site known to have ADB present.
I have been monitoring them for the last 5 years, until now, all good.
Today I inspected some of the Syrian Ash, as I approached I noticed the dreaded tell tale sign, die back of the crowns resembling hedgerow trees.
What I found surprised me and I have never seen it in 26 years of Forestry. These are native Hornets completely ring barking  and stripping bark causing the tips to die back, anyone seen this habit before, and why only the Ash?
I think the answer is either they are chewing it for the wood fibres for their nest, or they are being resourceful and taking the sugary sap from a wound made by somthing else.
When I did my cs39. It was at the end of the summer and the assessor in his risk assessment said wasps in the tree. My reply was if they are the big from down here, then there hornets.
However, he said there are only a few. Are you ok to go up there.
I said yeh they aren’t interested in me.. after bouncing the branches about. The hornets were gathering up as they could not land.. when I lifted my ear defenders up. There was a loud humming.
I was asked if they were bothering me, I replied no they are just trying to land. But if they do hassle me I will come straight down.
Do you have any further details on this guidance? And is it relatable to dealing with hazard trees in general?
i have already heard stories about rigging point failures where climbers have used rigging blocks & the resultant forces have ripped the tree apart.
When I started in Arb, we were rigging out the last of the elm trees we used natural crotch rigging as there were few other options. This simple method helped massively reduce the forces generated at the rigging point. This has to be our end goal either through friction or load sharing redirects- either way we need to rapidly and radically reassess how we approach these rigging scenarios, as It is OK having all the toys, but a deficit in knowledge & or the skills to apply it will no doubt result in fatalities rigging out these hazard trees sooner or later.
I think the main problem when rigging die back ash when compared to elm is that ash is pretty brittle to start with so that even in the early stages that is exacerbated. We are working on die back ash here in West Somerset and trees a varying a lot. Definately noticeable that even in the very early stages that when doing directional hinges in the canopy they just dont hold.
Personally i have been trying to advise land ownera to catch it early as if it progresses it can not safely be climbed and of course costs will escalate!
Absoulutly tons and tons of roadside ash that has die backbround here. Dead standing trees, even if you didnt know about die back they should have been picked up as dead and dangerous trees!
When I chat to  landowners  & homeowner still most seem ignorant of ash die back even though often  many of the trees on there property are dying or dead.
Ash is the dominant tree here as a %.
Find mentioning dutch elm helps them to get an idea of the impact as some remember that.
Maybe there should be adverts on TV pulbic information broadcasts like there used to be?
Hi Pete, unfortunately not, it's with Head Office being branded etc.
I don't believe this guidance will cover rigging in detail other than advising not to, in general, and only at Stage 1, ie very early on.
Hope you're well,
Paul
10 hours ago, Paul Cleaver said:
I will be shortly survey trees railside mainly in the South. I expect I will be quite busy. I am expecting some areas where "clumps" (for want of a better word),  of ash trees may need felling. If this is the case I will have to determine whether immediate replanting should take place on banked areas to avoid landslip!
Sounds strange, after we felled trees, and treated stumps, on a steep chalky embankment we had to go back and pull the stumps out as they came loose several years later.
Remember when the railway was built there were no trees and kept that way by the deveg gangs.
Hope you're well,
Paul
I think there is some scope for further guidance in that case as this is going to be a huge issue imo.
Sorry Pete, the forthcoming Technical Guide (TTG3) is the 'rigging guide' which obviously will cover anchor point selection, strengths and weaknesses etc. albeit not specific to ADB.
That'll be why they made axe handles from it then ?
I felled some large affected ash last week, 60% crown dead, and there were definite signs of something strange in the basal cross section. Whether it was a secondary infection or signs of the chalara  infecting the whole sapwood band I'm unsure. The hinge was still as normal.
Strange to me too. IIRC someone mentioned about how stumps of infected trees were coppicing the following year, before that foliage got re-infected. I'd imagine the remaining roots would stabilise the bank for a number of years while nature took its course and new self-seeded saplings became established.
As a sidebar Paul, when did you become qualified enough in geology/geography to determine where the angle of repose would lead to slippage? :lol:
That'll be why they made axe handles from it then [emoji846]
Perhaps my terminology was not on point thur my man. Perhaps if i said it doesnt hold a hinge as well as some of the other brands of trees.
One things for sure when adb branches hit the floor the make hell of a mess! Need to purcahse a road sweeper, did have one by chance go up the road i was working the other day saving me some work!
