I'm pretty sure I know the answer to this but I need to ask anway. Does anyone use rigging rope thinner than 12mm?
I've never seen it. I have a bit of 10mm static I use for a speedline once in a blue moon.
Like I said, fairly sure I know the answer but if five or ten people could chime in to confirm, I'd be very grateful.
Rescue rigging, we use 11.5mm. Knowing how quickly the kN build up, especially when the load bounces a bit, and even when shared across two identical systems, would make me worried about taking even moderately sized bits on a rope that size unless they had a guaranteed soft catch.
That said, I fully intend to add an 11.5mm rope for light bits one day.
Ive used 9mm in the past. Rigging smaller branches from very high, often need a light rope to help the stuff come down. Its probably against a rule somewhere. Micro rigging!
10 mm English braids was my go too light rigging rope for years, I’ve gone back to 12mm as it’s bright orange .. it’s a bit heavier for negative rigging and isn’t like cheese wire.. although I do miss the 10 at times it wasn’t visible enough for special needs groundys.
  • Haha 3
I had a 8-10mm 25m length of polysteel that I'd use as a climbing system retrieval line.
Since it was with me in the tree I'd rig bits off themselves with it - either taking wraps or using a fig 8.
It was useful to have when pruning and wanting to control things. I can see the benefit of having a smaller diameter rigging line instead of dragging a big dirty rope around a reduction in a tight space.
I have a 10mm line in a bag with the rigging wrench and loopie, for brushing out small trees (most of what we have here) or something needs string on a reduction.
Wrench is only rated to 70kg anyway so 10mm is plenty strong enough, nice and light, and not too draggy in the wrench to pull through. Think it was @Ty Korrigan who suggested using 10mm in it.
