Another NOCO fan..here👍
Get on Amazon sale...started big Deutz on screener a bit back...👊
Ruddy handy bit of kit.
But...make sure you buy the 240v charger adaptor...charges it properly and v quickly.
Bought one of these a couple of years ago works well even on larger diesel engines, started tractors.
HILKA PRO-CRAFT 83850400 400A LI-ION POWER BANK
£82 Screwfix
Edited by petercb
I’ve just bought the Noco 500A one after a persistent starting problem with my chipper.
It turned out the battery was goosed so I bought a new one.
I thought it would be a good addition to the glovebox, though, although I haven’t used it yet.
Annotating the Transit and chipper for a jump start was a pita.
Apparently this one will also start my truck if required.
Just as importantly, I will never run out of phone or vape power on site again thanks to the USB ports!
Handy for events like the APF as well.
Torch seems ok.
£90 from Halfrauds.
8 hours ago, Whoppa Choppa said:
I'm thinking the smaller ones aren't as good. I've got the 3000A one (will get a pic later) and it's been faultless. It's started a 6.8 litre diesel iro 20 times before needing to be recharged. A note re charging - even though it is officially fully charged once rhe green light is on, it will carry on pulsing for a full day (ooh er). Leaving it til it's stopped pulsing may be the key to ensuring proper performance.
Torch seems ok.
£90 from Halfrauds.
Running out of vape battery is this decade's version of losing your lighter.. highly vexing. I don't run out of phone anymore though, after renewing with a 8000 mah rugged phone.
4 years or more since I got a noco and it's only now starting to lose its oomph. Has started all manner of machine including the mog.
Good little device, but I have noticed it's no longer up to starting larger engines. Wouldn't be without one all the same. Its proved useful during power cuts and when camping too.
I usually keep it topped up from the 12v charger in the jeep, it might get a full mains charge twice a year, this may have had an effect on it.
I've got a Honda ed400, little suitcase generator, not made anymore. The only outputs on it are 12v and 24v.
You can hook it up to a dead battery, go off have a cup of tea and come back to a charged battery.
Handy if you can't get another machine/vehicle to the dead one for a conventional jump start with leads
After reading a few reviews I bought this 4000amp gooloo for about £100, model number GP4000. It can wang over a tractor engine for a surprisingly long time.
GOOLOO.UK
GOOLOO flagship jump starter power bank; 26800 mAh with 4000 A peak current; one button back on track.
Edited by aspenarb
I've got a Noco GB70 that I've never managed to use to start anything. Either it doesn't work or I'm too ****************ing thick to grasp the instructions. Anyone care to offer instruction in terms the tech-averse might understand?
