7 minutes ago, trigger_andy said:
Learn on the job seems to be in the way out. At least here in Scotland. All have at least Collage time built into their “modern” apprenticeship. But before this you still had to be “time served”. That’s normally a four year apprenticeship then you get recognised papers.
Yes it does seem like it's on the way out along with taking people's word for things. Having just moved I spoke to a few companies about work around here before I got sorted, most of them wanted a CV. What's that about?  I've told you what I can do, do you (they) need it written down!😂
22 minutes ago, Joe Newton said:
Not for climbers. Demand way outstrips supply at the moment. Ask any company owner how easy it is to find a decent climber or even subby.
Are you able to up your rate due to lack of decent climbers?
One of the climbers I used sent a text to say his day rate was going up to £250.
I ask when his next available date was which was February.
Its about time that we start changing what we are worth.
Correct about sparks and gas engineers but most of the other trades I know learnt on the job, Brickie's, joiners, plasterers. Very few of them saw uni or college.
Have you seen the state of so called workmanship on building sites these days, its diabolical. There are very few actual craftsmen around these days.
Same with chainsaw operators! Plenty with tickets but when you get them into the wood you soon find out most of them are fecking useless 🤦‍♂️
about 30 35 years ago there were the 6 month wonders (brickies) half the stuff they built had to be pulled down again it was costing the firms a fortune in extra materials
Sounds about right after the miners strike and every pit got shut down. All were retrained and so called experts.
Not only brickies, research Ronan Point and missing bolts. I had much trouble with second fixings; vapour barriers and cold bridges on a couple of refurbs at work.
When I didn't go, collage was spelt differently.  But then, we didn't have spell check when I was a yoof and I ain't improved!
