Heated saw handles pros and cons?
drinksloe
As a point of caution, some husky saws come with a heated carb option too. Easy to cook a saw with that so I have always disconnected it (apart from the time I removed the wrong wire & killed the saw on a nice warm summers day, when I had accidentally knocked the switch on !)
On 30/01/2021 at 18:46, Peasgood said:
 Always assumed they just used the heat of the engine in some way.
I think there were some Partner saws which diverted the exhaust through the handles but it's all electric now
Never felt I needed heated handles because I am usually too hot anyway if using a saw.
Well it never gets really cold in sunny Surrey but I do switch the heaters on when my gloves get wet from dragging brash, you can switch it off as soon as your fingers are warm again, it doesn't take long ringing a few chogs.
Spot on, i always do the same
Where is this to unclip? Never done this on my 550xpg.... Cheers
