I recently ordered one of these. The surprise is that it’s more robust and better made than I expected. Also the service from order to delivery was very good!
The design is not rocket science but perfectly ingenious.
I just thought it worthy of a mention.
GROOVYTIMBER.COM
Groovy Timber™ sells unique outdoor wood log stores that enable you to easily and automatically access the best logs for burning in your log burner and on your open fire - every time. The Firewood Feeder™ stores wood in a unique way and seasons them so they burn more effectively, glowingly and safely.
GROOVYTIMBER.COM
Groovy Timber™ sells unique outdoor wood log stores that enable you to easily and automatically access the best logs...
I would want to stack it properly rather than just " post it " through a slot . just me .
  • Like 6
GROOVYTIMBER.COM
They must have big windows. :D
Edited by trigger_andy
13 hours ago, devon TWiG said:
It can't be that easy trying to pull one out from the bottom of the pile ...seems like a solution to a problem that does not exist !!
Then you should try it - especially as the problem of having unseasoned wood to burn does exist! Just saying.
