Hi
i am thinking of going into the shed to cut
up logs in the dark and rain
so considering the most powerful  stihl mains electric  saw
it says 2.1 kW power consumption
does that mean it is equivalent to a 2.1 kW output petrol saw ?
if so that would be enough
any first hand experience or opinions welcome
thanks
You may not need the top of the range saw:  I have a mid range (I think) 25-year old leccy Stihl saw and it's brilliant.  Don't let 'electric' convince you it'll be gutless.
Haven't tried the Stihl, but I've got a 2kw mains electric titan chainsaw. Cost me £50. Only had fairly light use as most of my chopping isn't in range of a plug, but it does a good job and cuts surprisingly well.
Don't forget to fill up the chain oil as it won't run out of fuel to remind you!
Good point; my saw has a tiny oil tank.
17 minutes ago, spudulike said:
Got a little Black and Decker mains saw for using in the summer when people are in their gardens and a ported 395 is a bit loud. Works OK and fills the log store!
Not as much fun though.
