I'm in the market for an angle grinder. I do not want a cheap one but one that will be for the job. It will be used for sanding and carving I guess. I'm presuming a Bosch or Mikita but which model is recommended. Around £100 mark maybe?
Any suggestions much appreciated.
Cheers Sean
  • Replies 21
Cheers Sean
Hi Sean how you doing mate my mate use hitche Sean thanks Jon
Cheers Sean
i think most angle grinders are much the same but i think you'd be safe with a makita.
I used and abused a 4" Sealey for many years, cutting car panels, slabs, RSJs, all sorts - lasted far longer than it should have given the beating it took. Currently using a Bosch for the last few years - also seems pretty robust
I've used bosch for years, they're pretty good.
Recently bought a dewalt variable speed which is really handy when full speed is too much. Should be able to pick one up in your budget.
Cheers Sean
If you fancy something a little different to Japanese made then I highly recommend "METABO" . Iv got cordless kit and there grinders are very typically German built.
