2 hours ago, doobin said:
That’s some messy welding.
It's better on the other side but agreed it's not exactly slick.
As long as it stays together I will be happy though
Minor Fings Wot Broke...
That wee safety button on your chainsaw you need to hold in to get it going/nothing works without it. No more than a shaped plastic pin with a tiny spring. Aye ... it broke 🙄 Very minor i know. But Soooo fecking annoying 😖
  • 3 weeks later...
Not really broken, but non working anyway!
A friend's esab welding helmet with a flat battery.
As is often the case, you need to take the thing to bits, and the battery is soldered on to the circuit board. They don't want you changing the battery!
Previously I have soldered in new batteries, but on this one I got a cheap little external battery holder for a CR2032 cell, which is slightly smaller, soldered that to the circuit board, made a hole for the wires, and stuck the holder to the helmet.
Edited by scbk
Bent a set of qfit tines. Valtra trailer plug cover broke and the one with the fancy connector that just quick fits is on back order. JD6155 pickup hitch push back tube welds cracked and needed replacing. Valtra's water pump went but thanks to being cold it was a quick spot so hopefully no big damage. Oh and Friday morning the telehandler pump feed split. FML.
Finally got my gx390 from my tracked dumper running again. After replacing the coil then the switch and key assembly with no progress, last night I realised that 2 of the wires are black and easily fitted the wrong way round. Turned them round, job done👍👍
Putting it all back together tomorrow.
