Not the first weld that has failed on the machine! Forst st8 bracket that holds the hydraulic oil filter on, its seeping oil out and tomorrow we will have the welding guy in to try and sort it out.
It’s wearing a bit thin (my patience)
How old s the machine?
On 28/07/2017 at 17:40, PeteB said:
No names mentioned here but can you imagine the call to the boss about his new GreenMech which had a lump drop on it?
Long time post ( just seen it ) I would be fishtailing the transit van out of there ! Ohh my word ! K
I guarantee you it’s from the crack, we spent ages isolating it.
I don’t know anything about the Forst machines tbh - is that the hydraulic tank it’s welded to? From the pic I guessed it was the bottom of the rotor housing (hence my confusion).
Same sort of setup on a jensen with regards to the hyd tank i suspect.... the tank is litterally under the chip chamber and the sides and bottom of the chip chamber make part of the tank up
That’s right, the curved bottom of the rotor chamber is the top panel of the tank.
