Fings wot broke
aspenarb
few repaires on the A540t,started off with i will just get the top roller out & sharpen it up to find blades totaly shagged & ball bearings missing out off the roller shaft :thumbdown:half the balls had found there way out ,both its off hopper off later bottom roller resharpened ,then bust the cut out swtich ,easy fix :biggrin:then gave the track motors a clean out ,
used a cutting dosc to do the roller as it dosant over heat the steel, just takes a tad longer
