1 hour ago, aspenarb said:
Most waxing is down to the water content Bill, made worse with low fuel levels because of water content as a percentage. Not hard to check holding tanks and machines, there is a paste called Kolorkut , smear a bit on a stick and dip the tanks, it shows up water within as a red marker.
Bob
Water red diesel mix.
Lot of water in that small drum then 😮
Imagine the amount in a 25ltr tub then dumped into a machine!
It’s was a demo Chris, I put the water/diesel in the bottle to show the paste working.
Bob
  • Haha 3
  • 3 months later...
22 minutes ago, Mick Dempsey said:
Looks like the flywheel of a GM.
What are we supposed to see?
That what you can only just see is the middle bearing of the flywheel on a 1928 ... the casing has come apart and you can see the bearings now 😞
Mad a rumble at the end of Fridays Job so now needs new flywheel bearings 😞 least I caught it quick though hopefully
Disc chippers are such a shit design. I mean, they work, but drums are supported both ends. Why wouldn't you.
  • Confused 3
