13 minutes ago, GarethM said:
Doubt it has a reduction planetary gearbox, just relying on pure low capacity hydraulic grunt from pressure at 210-300 bar.
There's a calculator somewhere, plus it depends if it's a standard pump or a piston type.
Two hoses are in & out, smaller is just case drain back to the tank.
You'd be surprised how simple a lift assist cylinder is on a tractor, but two of those is 3-6 ton depending on model.
Then why the creep if the motor is replaced?
Even if the hydraulics are disconnected.
Edited by Mick Dempsey
Case drain I guess, plus hydraulics pumps don't form a complete seal internally and does bypass ever so slightly so always expect a little movement.
The big boy forestry ones a think have a clutch setup to prevent that creep.
There will always be creep as some oil from the high pressure side seeps past the spool valve or to that drain line on the motor. On track motors a brake is applied if there is no pressure being sent to the motor.
If it is leaking past the spool valve you could fit a check valve in the supply to the winch.
Thanks, the spool valve is out of the equation, as I said, you can disconnect the hydraulics and the creep continues till it’s ‘happy’ with the pressure.
4 minutes ago, AHPP said:
What’s the brake on a track motor? I always assumed it was a check valve.
Bit impractical as you'd need two.
More likely it's not got a case drain and the valve block handles both forwards and reverse, effectively acts like a isolation tap and uses the weight and tracks as the dead weight.
I do appreciate the effort put into the reply, Gareth but I couldn’t safely believe you if you told me grass was green. I actually have you ignored so I can’t accidentally learn anything dangerously wrong from you.
Hoping to hear from Andrew. I should have quoted him.
Edited by AHPP
  • Haha 3
5 minutes ago, AHPP said:
I do appreciate the effort put into the reply, Gareth but I wouldn’t believe you if you told me grass was green. I actually have you ignored so I can’t accidentally learn anything dangerously wrong from you.
Ignore whatever you want, but I'll think you'll find I'm not far from being correct.
Dangerously wrong!, are you actually taking the proverbial.
Thinking about it, it can’t be as simple as a turning a shaft inside the drum to turn the unit (in the same way as a motor turns a feed roller on a chipper) because that couldn’t generate the force that the drum produces.
Why not? Hydraulic motors are torquey even the gear motors. What's the pull and can you get a photo of the face plate for the specification?
The
The
I’ll get a pic tomorrow in the light.
