Large Drill bit for steel rod bracing approx 1.5m trunk
Tommy O
Maybe need to get creative with some steel bar, buy a long auger bit and Loctite an extension on. I've extended drill bits with high strength Loctite, its plenty strong enough to pass the drive of a drill.
Otherwise the green oak framers probably have tools for this but guess expensive.
From past experience of boring a 25mm hole in some oak at a depth of 550mm, it wernt good to do but i was going with the grain, i think across the grain would be easier, use plenty of candle wax on the auger bit and for gods sake keep pulling the auger out to clean the hole out or it gets blocked up and the auger goes solid, (had to split one length of timber to free the auger) and take your time as i burnt a £140 Boch SDS drill out after 2 holes,,,,
Just buy the auger price it into the job. if you win you get auger for next job,
trying to bodge an auger to drill that  will only end in tears, if it comes apart half way through the whole just how are you getting it out, you will need a pretty hefty drill to power it I get mine from Swiftfix in Southampton 02380446644
they can make any size you want up to 2.4 metres In length
Edited by dumper
Spelling
Expand
An SDS is totally the wrong drill for the job. You need a low geared high torque drill like oak framers use. I have the Milwaukee variant.
FFX.CO.UK
The Milwaukee M18FRAD2 is a 18V FUEL Super Hawg, 2-speed, 2nd generation right angle drill driver. Ideal for...
FFX.CO.UK
Expand
Thats ok but wouldn't the SDS Milwaukee Fuel ( that I have ) M18 CHD be better . The Hawg has a key chuck where as the SDS Max fitting would not slip . ?
Edited by Stubby
Read more
