Anyone got any idea where I could buy some second hand road spikes? Ideally like these cheaper!!
True Products 10 x Strong 10mm Steel Fencing Pins Road Pins 1.25m for Temporary Fencing
WWW.AMAZON.CO.UK
True Products 10 x Strong 10mm Steel Fencing Pins Road Pins 1.25m for Temporary Fencing : Amazon.co.uk: DIY & Tools
Some of the new cheap ones you see are made out of quite a thin bar, so flimsy, not like the old ones. You don't see them being used much now, it will always be plastic barriers or heras fencing, 2nd hand would be pot luck, try scrappys or industrial auctions
Quote
The ridged ones look more a chunky diameter than the smooth but theres two different type of ones  in the pics?
Fencing Pin - Steel 1.3m x 8mm diameter. Used for the speedy erection of barrier mesh and similar style netting
I used to use them for a line, for coarses, whilst dry stone walling and the  modern ones were thinner.....
Edited by Stere
