54 minutes ago, Mark Bolam said:
Slight derail on the attachment/welding stuff, but does anyone have experience of working on ground protection mats with mini loaders?
We have a few jobs I could tow the chipper in with, but there’s lots of moving brash and timber (albeit staying on site) and the shift from the drop zone to the landing would look like The Somme if we do it now.
Piss wet through heavy clay.
Might be able to borrow some mats from a civils contact.
Got 6 sheets of 9mm stock board which we use to move small loader and digger about on, also use them to move tracked mewp around. On a large job early last year we used them as area to leave brash to chip near chipper. Which i had bought 12 at the time now.
Work really well, had to get extended forks to move them about can get a little slippery if on slope used on turfing job ground was too soft even to walk over
We used to use stock board as well.
I made ours go further by ripping them into 3 length wise, if you put one 3rd down for each wheel you get 24ft of road from 2 sheets. The small skids will turn on a half sheet easy enough. (Cuts like butter with a circular saw)
I use 6” nails through a hole at the end of each road section and 3 on each side of the turning boards to peg them down to lawns so they don’t slide about when you turn.
6mm will take a little loader no bother but struggles with a truck.
Stockboard all the way, it’s all you need for a mini skid. I’d leave a whole board for turning though. It’s not just the room needed for the wheels, it’s having enough that the whole board doesn’t slide
Edited by doobin
yeh i've recently got some to run the avant around on at the farm where i do logs as its a bog in winter
makes a huge difference. they are expensive but worth it
i got a bunch of second hand ones on ebay
i move them around with a Oregon lifting hook, as they have holes around the edge of the mats!
  • Like 6
That's a great idea.
@AHPP
  • 1 month later...
On 30/01/2022 at 08:28, doobin said:
Made up a backing plate with multiple bolt squares on it, so we can use attachments either with digger bracket or Sherpa bracket. Four bolts with the impact gun is a small price to pay to save having to buy dedicated attachments.
should fit my grab, post knocker, breaker, auger and even my mancrate for small garden hedge jobs.
Great idea, I would like to do something like this for mine. What make log grab are you using?
Intermecatto mate. I only buy the best!
