6 hours ago, eggsarascal said:
I don't mind gutting my own fowl but I draw a line at gutting my own foul.
I'd heard you would skin a turd for a farthing Egger 😊
1396651.jpg?imageId=1396651&panow=0&panoh=0&panox=0&panoy=0&heightw=0&heighth=0&heightx=0&heighty=0&width=1200&height=630
PARTNER.SCIENCENORWAY.NO
Birch forest is currently expanding in mountain regions because of climate warming and reduced grazing pressure. A recent study shows that increased mountain forest promotes climate warming. Just to put a bit of perspective on this issue, tree planting is not always a good thing, but I’m sure you all knew that anyway.
Could it be that the tree line is creeping up because of global warming rather than causing it ?
They don't say why there is less grazing, once that reduces trees can get away. Yes a warmer environment will mean trees can survive in higher colder places but here the point is once they start growing there is a positive feedback effect.  Trees absorb more light, which turns into heat, as snow does not settle on them, flat land covered in snow reflects the light back out to space.
The article suggests the increase in heat caused by the trees changing the earth's albedo at this place outweighs any benefit the carbon sequestered by the trees gives, hence making the earth warmer and increasing the ability for trees to grow further up the hill.
On 17/12/2020 at 16:01, ESS said:
Both beet and milk are produced on quota . Its not a question of the beet factory refusing to take the whole crop, however they are under no obligation to take any produce above the contracted tonnage from a farmer. Excess sugar beet ends up as fodder beet .
The same applies to milk, excess milk is usually fed to young stock. Milk from cows that have been given antibiotics etc has to be witheld, as does milk from newly calven cows , so at certain times of the year its quite possible that milk has to go to waste. but in both cases the costings would be based on the level of quota rather than the level produced.
Point of order- quotas are no more for either. These commodities are produced on contract, often an amount per ton or litre up to a certain quantity, then a lesser price for any oversupply.
11 hours ago, Stere said:
Alot of different feeback loops in climate change....
Yes, I skimmed through your link and the positive feedback resulting from non permafrost releasing methane and peat bogs respiring CO2 as well as wildfires but was not so happy about the claim that as things get warmer more water vapour will be in the atmosphere (it will) and trap more heat from leaving the earth. My understanding is that all the wavelengths of infra red re radiation trapped by moisture in the atmosphere  are intercepted already so adding water will not trap any more.
Infrared window?
Closing window warmer earth... think clouds and co2 can act to close window as different IR spectrum than water vapour....
Feedback:
WWW.NEWSCIENTIST.COM
Water vapour is the most important contributor to the greenhouse effect but human emissions of CO2 are driving...
high & low clouds....
https://www.metlink.org/wp-content/uploads/2014/05/FAQ7_1.pdf
Edited by Stere
