25 minutes ago, stihlmadasever said:
Aye ?
I actually made one ages back but it failed a loler and i got the pulleysaver.The wee thimble prussics handy too!
I have no doubt that the pulleysaver will be as good as a rope guide but I’m a bit of an anorak with ocd so it would do my nut in to have an art positioner SJ3 and a pulleysaver ?‍♂️ Hence rope guide ?
Same for clothing I’m all arbortec at the moment but that’s about to change given its last-ability.
I use a 2m multisaver as I was too tight to buy the pulleysaver. I use it a lot, for the two uses you have described but also when it's over a union you can set it long which moves your rope away from the stem as you move around and thus saves rubbing below the rings.
https://www.teufelberger.com/en/products-services/tree-care/application-specific-menu-treecare/tutorial-videos/multisaver-multianchor-und-ringloop-in-anwendung.html
I would use a pinto than a hitch climber , rated a lot higher. Hitch climber 36kn pinto 50kn hitch climber is ok on double rope loading but not sure how much I would trust it on a single pull... maybe I’m being well to over cautious!
Its a valid point matty,and id add to the above statement that if the pulley bearing goes on the dmm pulley your takin a header where as the pinto has a becket that would catch your rope in the event of a failure.
  • 4 weeks later...
On 23/01/2019 at 21:28, DanBous said:
Thanks for the answers so far guys.
I'll pop a picture on here of an acquaintance using a sling and a pulley.
Your thoughts much appreciated. Is this safe? Why don't more people do it?IMG-20190123-WA0000.jpeg
That picture looks strange some how.
top harness, petzl zigzag,best karabiners and a makeshift anchor system
I wouldn't be massively comfortable with a carabiner that far away from me as an anchor.
If my mates sent me that photo or were using that on a job with me, I'd tell them not to, very quickly.
I don't think the proper versions are that expensive for what they do compared to the risk associated with using the wrong equipment IMHO
Ditch the karabiner and use a maillon
