Ok forgive any lack of terminology or general lack of knowledge
I am very slowly improving what little processing ability I have for firewood etc I need to start to be able to move snalll and larger lengths of timber round my paddocks to both improve production rates and do a better job of housekeeping the timber as at present any timber is moved by hand yes ! By hand lol and I’m not getting any younger ! 52 ! Lol
i am In unfortunately position of low budgets to hand and also my lack of knowledge on what machinery suits this task so please try to understand the later two points count !
I was thinking along along the lines of possibly an old telehalndler with some type of grab to move timber ? But it will be an old bit of machinery as at the moment that’s the way it is money wise
or is thier a simpler cheap way to achieve this ?
There's quite a few ways, do you have a tractor or quad bike? Both of those could tow a small timber trailer with crane and grab.
If you're buying a machine you have a variety of choices with pros and cons.
Tractor and front end loader - loads about, can do other jobs.
Telehandler, skidsteer etc with pallet forks or grab - better for moving stuff but limited for other tasks.
Digger (360) - very maneuverable, good for stacking, slow to move.
Quad and trailer - probably cheapest if you get a trailer with a hand winch but you won't move much, if you get a trailer with a crane it could be an option though.
That’s brill advice
I’m leaning to a cheap telehandler as I can then double up I I get a bucket for it to use on my small holding to scape up crap and waste too I will only be able to afford £4 to 5 k max so it will be a old machine etc
what i prob need to understand is what grab / forks I need to grab and move wood ?
i think I’ve seen somone use a fork / grab that was intended for silage ?
Shouldn't go wrong with a telehandler - just got to choose whether you want a traditional side boom type, front arm or skidsteer depending on terrain and where you want to go.
You can use a muck grab for most stuff and they're good for brash or you can get a grab for pallet forks which is better for big stuff like this (be aware the pallet forks often aren't included).
http://www.riko-uk.com/product/timber-loader-grabs/pallet-fork-grab
I would've thought the ideal machine for moving timber and general small holding duties would be a smaller tractor with a front loader :stoned:
That is the way i would be looking,Maybe something with a pto so can use other stuff via it.
Yeah it is worth bearing in mind an old telehandler is a big heavy machine.  I have an old Sanderson 2 wheel drive telehandler and it does the job well, but it is 6 tons unladen.  That is a lot of moving parts to maintain, and the four wheel drive ones have even more moving parts.
Get your self a piece of paper and write down what you can do with a telehandler and then a tractor with loader. You will not have the lift capacity with tractor but from what you say only got small lumps to move.
Cheap telehandler will be a heap of sh..
