T Mech Stump grinder
aspenarb
The lads doing the domestic work have been moaning their holes off about getting a stump grinder they can throw over a fence so I bought one. Got a T mech , phoned up the guy selling them and he reckoned of the hundreds he has sold only one has come back with problems. So here we go and a grand including delivery later :)
3E1CFE0A-2BCD-4BB9-8395-05E8CFDAD2C8_zps
What lurks within ?
175446CE-AB37-41B1-82A2-4D7A70A54DB1_zps
Comes built up with the exception of the wheels, brake and the frame with the throttle and brake on it,
342F6B38-9343-4D7D-989C-815D2AD905F0_zps
216545E3-653E-4A43-9FE3-2D39DF0CD972_zps
Throttle control is decent with a ratchet/thumb  mechanism.
2857FC5A-636E-4788-A4ED-453729E3F24F_zps
Kill switch and deadmans cord
D9DFCF7C-D282-4C41-8605-30343CE984CB_zps
Cutter wheel is mounted on a couple of plumber block bearings with the industry norm exposed and vulnerable grease nipples, teeth have a good amount of carbide on them so should take a few sharpens, a new set is £65.
78B5ABDD-0095-423D-B45F-9E39F816416B_zps
F2017924-39C7-4C9E-AAD1-40FD0F89F30E_zps
Skirts are made of some sort of hard vinyl shite  , think this will get changed for some rubber.
D7F95F0E-5DB4-4392-B7F8-30FAB68F627C_zps
Fecking thing is blue :thumbup1: Started first pull, its on a centrifugal clutch . will see how it goes.
A37029F0-5A16-4A7A-9C90-A1D013F09F68_zps
i got a little rock stump grinder, 6.5 hp jobbie.
been a cracking machine, saved the day when the predator 28 puked its guts up and had to do a 2 ft dia holly.
Dont get me wrong its always last choice but it gets where virtually everything else bar a alpine magnum wont.
and cheap!
not worth getting rid of as it paid its self off in about 3 months of minimal use!
These little one definately have their place!
18 hours ago, Stumpy Grinder said:
Interested to see how this goes. Doesn't look heavy enough to me and will probably bounce off a decent stump. Certainly cheap though and will go through a 2' 6" gate. Hope it works out for you and look forward to hearing your review!
SG
Its 13hp and the same weight bar a few kg as the rayco  RG13 ,   there is an old willow stump in the yard so I will bounce it off that tomorrow and see how it goes.
Bob
Bob
Willow is a test for any machine! Give the poor thing a chance!
I think willow and silver birch are two of my least favourite types to grind. Very fibrous and require sharp teeth!
Worst one ever was a Holme Oak which was absolutely massive and had to be taken out completely! I've never seen so much wood underground.
