Best way for moving big timber?
Chris1976
A lift trolley if the ground's flat enough.  But they're expensive and the terrain for them needs to be hard and fairley flat.
Once the log's at the truck you can wind the trolley up to floor level.
Cut it up smaller? Only a part time groundy but I dont get why you guys like hauling massive of lumps of wood back to base that in a few months time you cut up small to make some firewood. Just cut it down to manageable sizes there and then on the deck. Yes more chip to clear up and takes a touch longer maybe. But you dont bust you back and every stage from there on is easier.
I will get my coat
Edited by Woodworks
