  • Replies 49
Really rate my 1 and used it lots especially for compromised trees or when we are running as a two man team as climber can hold control the rope while groundsman controls the limb being lowered
My 1 did the same once so I whipped around the top to tighten it up a bit and been fine since.
Sent from my D5803 using Arbtalk mobile app
I'll try that or Mick's idea.
They are good lucky , I would buy another if I had too... hopefully will last a life time !
Ive seen the single rings for rigging but never the treble (safebloc).What would be the need for the 3?
Sorry im bit fick sumtimz
SafeBloc is a triple hole thimble that adds friction in the rigging system to the top of the tree, thus adding safety by reducing rigging point stress, compared to a system that uses a block or pulley
It adds friction like a lowering device , if you use a bollard your doubling the force on the top rigging point.. this acts like a bollard at the top of the tree, they are pretty smooth and easy to use.
Just carry on crotch rigging in those situations Mick.
It's a lot cheaper than this bollocks which will potentially kill you, as Matty has pointed out.
