hi
i have a few barrow bags in a poly tunnel for next winter
would you
leave doors open on dry days / every day for the breeze
leave doors shut for the max heat
leave doors shut and open the window
whats best ?????
in todays sun it was really pretty hot in there for march anyway
just curious i imagine they will be ok whatever given all whole summer in there
thanks
david
as far as i know it is not heat that dries the timber.
i thought it was the air flow that evaporated the water from the surface and this drew out the moisture from further down up to the surface and so on and so on.
i think the heat makes this process quicker but the primary requirement is airflow, you can dry logs in cold countries...
Agreed. Combination of free moving air and heat.
