Hey,
Any advice on sharpening with out a vice? With a vice there's no dramas but I'd like to improve my sharpening without a vice for times on site when a saw needs sharpening. I'm not to bad without a vice but there's definitely room for improvement and I know you can get log vices, but some days you don't have an logs to use (like to today on a light reduction job)
TIA
Tom
  • Replies 22
  TTownsend said:
Hey,
TIA
Tom
Sit on top of the power unit so its between your thighs,lean over the guide bar and sharpen away.
Those log vices are overated..
if your that bad get a field vice
https://www.frjonesandson.co.uk/products-page/consumables/sharpening-equipment/sharpening-accessories-tools/oregon-bar-vice-heavy-duty/?gclid=CLL6z4XF_NECFaIW0wod4O0Fhw
other than that get a flat surface and jam a piece of wood under your saw to make it sort of horizontal and trap it down other than that .............................. practice!
Edited by Cheesy pete
You'd be surprised how little force you actually need to sharpen the average saw chain provided the file is good - even if the chain's in pretty bad shape - less force just more strokes! This means you can get away with just perching the saw on your knees or on a flat surface like the tailgate of a truck. Hold the bar steady with one hand and file with the other. It becomes second nature with a bit of practice! A lighter touch will make your files go much further too!
I often find a log or another tree and prop the saw with bar tip up at a reasonable angle with unit between legs. Then work up the bar, then lift and spin chain down with file and repeat.
Works pretty well
I sit cross legged. Handle shoved under my bum, body of the saw sits on my calf. My thigh stops saw rotation against the side of the saw as I file and the chain is free to spin. Swap legs when changing filing side so you're filing against the leg that is 'locked' under your knee.
If it's a decent length bar I sometimes find a smallish tree ( 4" ish) and put a vertical bore cut in at a comfortable height then just hang the saw in that while I sharpen and just lift the saw and drag the chain round as required.
Obviously no good if you haven't got a tree to sacrifice.:001_smile:
Read more
