Re-grind the hook profile to make it more acute.
Manufacturers don't seem to make hooks sharp anymore.
Many years ago my old man had a cant hook with a wooden handle that he used to roll oak logs up to 3 ft diameter on to a saw bench. It had a point like a needle and would bite in without any help. Shape and point angle probably very important too, possibly a lost art now?
  • Replies 52
Evening all,
So I have one of these.
And whilst its ok as a felling lever using for anything else is pointless. The black hook just does not hold. What is wrong? What, if anything can, I do to fix/improve it. Or worst case what else should I buy?
Thanks
Chris
Sent from my iPad using Tapatalk Pro
operator error :biggrin:
As mentioned, the felling lever is fine and I always have found the hook to be an irritant. I find that you can jam it to one side of the bar near the handle so that it does not keep sliding down.
I have a proper cant hook for moving logs, one of these
Peavey/Cant Hook/Log Jack - Lee Valley Tools
However I was using the Palax processor yesterday and a log flipped up and jammed the saw blade. The log was stuck fast and wedged between the blade and the swinging table. I tried most things to move it but without success until I saw the Stihl bar. I had never really used the hook in anger but this time it did the job easily on a 14 inch round that would have been awkward to move with the big peavey.
So I think it has paid for itself just by doing that job!
I think that Stihl made the bar as a lever and then added the hook as an afterthought thinking it might just grab a few more sales. But I would rather have it around just in case.
Now I think about it I remember that I took the hook off and lost it and bought a replacement off the internet which may have been a better design.
talk to your postie and get a big thick elastic band round the hook, that should keep it in its stowed position. ive got a velcro strap round my hook ATM but the an elastic band is better.
Also sharpen and reground the point to get it to bite better in the log but i normally just plunge cut a slot and use the tip if i want to roll big trunks
Get a longer one.
Hold it as far towards the end as possible to get as much leverage as possible.
Grind the hook sharp and give it a kick to "set" it in the tree.
A long one is excellent for ripping old flooring up too!
