4 minutes ago, Mark J said:
Well, someone has to have a go.
Don't get me wrong, I'm not knocking it at all. I'm glad there's people prepared to attempt hold the ££££ makers/stealers to account. I'm just not very hopeful with such a broken system.
18 minutes ago, Mark J said:
What happened to your info about the superiority of Scottish water? On a par with Scandinavian I think it said.
Meanwhile the privatised English water companies are dumping so much into crap into the sea that we're pissing off our continental neighbours.
https://www.itv.com/news/2022-08-25/french-meps-accuse-uk-of-turning-english-channel-into-sewage-dumping-ground
May be an image of map and text that says "Water quality in England and Wales is poor compared with Scotland's Proportion of water bodies* by surface area failing to achieve good ecological status, by river basin district (%, 2015) 100 90 80 70 60 50 40 30 20 10 Excluding unknown status Source: European Environment Agency ©FT"
We're in a bit of a pickle as a country at the moment.
15 hours ago, Mull said:
Water? A natural resource like oil? Why should they charge for the provision of that?🙄
You wanna go to the well, burn or Lough wi a bucket, and drink the untreated water ?
Never mind disposing of all your shite within your own curtailage?
And obviously all that infrastructure, dams filterbeds, resovoirs and pipes are totally free to provide and maintain?
Scheesh!
3 hours ago, sime42 said:
Drop Fido, Drop!
You work out what a cuck is yet ??.
With a reply as feeble and impotent as that I think it’s plain to see you probably do actually realise you might have been a bit keen to say the least.
5 hours ago, openspaceman said:
How does that work with a meter then?
My water unmetered charge (includes waste as the bigger portion) is £400/annum. If I had a meter it would be about £150/annum, but priority for meter fitting is to people moving in to unmetered properties so they are not rushing to fit one.
As I understand it if you are metered you receive a monthly or quarterly bill if not it’s included in the council tax as a set fee. My property like a good few in Scotland has a bore hole with all the associated uv, ph and particulate systems in place. That and the septic tank qualifies us for a decent discount on our council tax charge.
Moving a lot OT; do you use an electric pump for the borehole and also treat all the water with UV?
Yes, I have an outlet for external use ie pressure washer etc that’s before the treatment set up but everything that comes into the house goes through it.
